Dreambox 500S Help Needed
  • nedkelly
    • Apr 2011
    • 17
    Tried to flash new image on my dreambox using null modem cable. Everything goes fine until I try to upload new image. Upload runs for approx. 20 seconds then stops with a info box appearing "Error- Aborted by User, Exiting". Box will not respond to any I.P. ping although I must keep the ethernet cable connected as well for the box to show "box is alive and talking to us ".
    I have tried three different images from Darkstar etc., all do the same.
    Box will not now operate. No images on T.V. and remote control does not do anything. H....E....L...P
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    untick use network on dreambox..shouldnt have to use any cable other than null modem and power to flash with dream up
    • Fergal
      • Aug 2008
      • 1007
      This is the 3rd thread you have started asking the same question and you have been given answers so please stop asking the same question all over the place as it will make it easier for members to help you and not go over the same solutions again and again
      stick to one thread here
      • nedkelly
        • Apr 2011
        • 17
        Did that already. Still the same. I saw a link on another thread advising to down load a file from Dreambox website but I can't find anything for the DM500s other than a firmware file.
        • nedkelly
          • Apr 2011
          • 17
          Sorry, Fergal, I'm new to this and couldn't find my original post.
          • nedkelly
            • Apr 2011
            • 17
            I did a backup before I started. It is an 8M file. I changed the file name to backup.img. Is there any way to upload this back into the box???
            • Fergal
              • Aug 2008
              • 1007
              What did you do to back it up and what type of file is it.
              • nedkelly
                • Apr 2011
                • 17
                I used the backup button on dreamup and saved the file as "backup". It saved it ok. I tried uploading different .img files but kept getting an error", aborted by user message. I tried uploading a copy of the backup file, having renamed it backup.img but still the same message.
                • Fergal
                  • Aug 2008
                  • 1007
                  Did you try the telnet way to flash a image on from the download section
                  disable your antivirus a firewall
                  also try a different versions of dreamup to flash a new image on.
                  • piopat
                    • 708
                    the error aborted bu user message means you are using the wrong version of dreamup ,you can download a version of dreamup thats works on a dm500s by clicking on the last link of my signature area.
                    i love it when a dreambox comes together.
                    • nedkelly
                      • Apr 2011
                      • 17
                      piopat, you and Fergal ARE THE MEN. I downloaded an earlier version and now, the unit is working but the instructions I have to share my card tells me to edit a ccam.cfg which doesn't exist. I downloaded the image from Darkstar 2. Initially, I had done a backup using Dreamup but I do not know if this file will be of any help. When I log on using DCC the box states
                      "Telnet Connected
                      FTP Connected
                      Model DM500 detected.
                      Bootmanager: not found"
                      I have a file on my desktop called Bootmanager containing a sub folder "skins" with six sub folders blank, mercedes, california etc.
                      Thankyou for helping me (and Fergal as well). How can I proceed to get these other things (clines etc.)
                      • Fergal
                        • Aug 2008
                        • 1007
                        You have to download and install cccam via the addons menu usually via the coloured buttons but it only works on certain images otherwise you will have to install it manually
                        what image did you flash on?
                        • nedkelly
                          • Apr 2011
                          • 17
                          I used the DK_v1.1.img
                          • Fergal
                            • Aug 2008
                            • 1007
                            Have you tried looking via the Button 2 xYellow = Nabilo Yellow Panel - Addons Manager
                            • piopat
                              • 708
                              fergal is correct press yellow button twice ,open addons download manager ,open nabilo image cams ,scroll down the list of cams untill you see cccam 2.1.3 complete and choose it by pressing the ok button .
                              now you will see aprompt asking if you want to install addon (say yes ) if you get a second prompt say yes ,the cam installs in seconds . when the cam is installed exit back to the tv channels and press the blue button ,you will see default cam and to the right of that you will see either default or common interface (depending on your box ) press the right button on thr remote untill default is replaced by cccam and when you see cccam press the ok button ,now exit back to tv channels .
                              cccam is now installed and the cccam.cfg file is in the var/etc folder in your box ,you will need dream control center (or simillar) to edit the file you can download it from the last link of my signature area .
                              sharing talk is not allowed so if you have any questions in that respect you need to ask them via pm .talk soon mate.
