cccam manually
  • patch
    • 69
    cccam manually
    i have a dm500 hd and its running cccam 212 , if i wanted to change to 214 , can someone explain how to do this as 214 isnt in the addons . thanks
  • cris808
    • 133
    What image are you using mate?
    You can add Tunisia Sat Addons and all the cams are available from there.
    • patch
      • 69
      using pli 1 , cccam 212 is there but not 214 , its running fine with 212 but just wanted to know how to input cccam manually if i want to change image as some images now dont have cccam in their addons , thanks . what is tunisia sat ?
      • cris808
        • 133
        Google "Addons manager v 3.0" and follow the instructions mate. I don't want to direct you to another site and be blamed for any potential trouble you may have.
        There's a few forums that have easy instructions
        • patch
          • 69
          thanks will i need to remove 212 before putting 214 on or does it just copy 214 over the 212. also i dont have a HDD attached , will i need to get one or should there be enough space in the flash for the tunisia addons . thanks
          • cris808
            • 133
            Yeah you will have space for it no problems. You don't have to remove it no. 2.2.1 is out now if you want the latest cam.
