hi, i'm new to this. id like to noe if i can use blackbox 500c for singapore starhub channels? if so, how do i do it? thanks in advance..
newbie seeking help
Tags: None
Hi
You need to do some reading to get going but it looks like Starh*b still uses Nagra 1 - that's unusual so this info might be wrong. If it does, then, you should be able to use blackbox.
You are probably in a better position than me to check what version of Nagra Starh*b uses.
Hope this helps -
