thanks for prompt responce
i got it off fleabay so i dunno
but ive read about CS and understand the theroy
not to worry im not 2 bad with files and linux
what sats would you recomend i look for as i have a motorised dish i just saw it on list and decided to ponit at it and start from there
just following what curious put in earlyer post:
Whilst you are waiting for your box to arrive you may want to download a few files;
The first thing you will need is your lat/long settings, check google map or mulitimap for the information.
The Captains settings for the channel list (equivalent of the Eurvox cdf file).
Dreamboxedit program for copying the channels list to your dreambox.
Dreamup program for flashing the firmware if your box does not have an image(this is similar to the Dnupman program for Eurovox).
The latest Satankey bundle for the sat keys this the sat equivalent of the 'magic files'.
An ftp program for copying files to your dreambox, I use a prog called Coreftp because it is free.
google is your best friend when it comes to satellite viewing.
Unlike to eurovox where all you need to do is plug the box in and scan, with sat you need to do everything in small stages. Once your installer has finished fitting the dish I would say that you will probably need to do all of the things I have listed with the exception of Dreamup. I would not bother with cardsharing until you have your dreambox fully operational.
When you have problems you need to come back here and tell us as clearly what problem you are having or what you are trying to do and what you have already tried so that people can help you sort out your problem.
Even with channels slowly disappearing on sat as firestorm says the sat will easily blow away cable when it comes to viewing. Come back to this post once you get your dreambox working and let us know if your ?400 was money well spent or not.
so what software should i flash my box with
bearing in mind i dont wanna use gemini in the fear i have a clone
and do you have a link for latest ccam and firmware image
manythanks
P.S cant find dcc download anywhere
manythanks
