db500 and web interface remote access problem
  • Dr.Strangeluv
    • 6
    Hello forum,
    I have a DM500 with Gemini 4.5 at home and I would like to access it via ssh - basically I visit my grandparents a lot and would like to be able to "play around" from there as well. Yesterday I was trying it for the first time at a friend's house, and decided to check the tuning, to see how it works. The problem is that when I tried to connect to the web interface, it refused to work. This is what happened when I tried the ssh to the dm500:
    root@dreambox:/etc> wget -O- http : / / localhost
    wget: Unable to connect to remote host (127.0.0.1): Connection refused
    This means that there is no web server on port 80.
    So my questions are:
    1 - Any idea why I do not get the normal web interface?
    2 - Is there a way to configure the enigma to start the web server?
    3 - Is there a way to remotely tune the dm500 without the web interface?
    Do I have hope to solve this issue or I should just ?
    thanks mates,
    the dr.
  • Curious123
    • 2591
    Have you set up dynamic host for your dreambox and forwarded the ports from your router?
    • Dr.Strangeluv
      • 6
      hi m8,
      yes, i did it and can connect to the dm via ssh, but still cant get the web interface
      any other ideas?
      the dr.
      • wmccull
        • 67
        Sorry to jump in.. but you did open port 80 and point it towards the Dreambox ?
        • Dr.Strangeluv
          • 6
          Yes, port 80 is open.
          I sent the wget from the dreambox itself.
          Anyhow, I tried the following at the DB itself:
          root@dreambox:~> wget -O - cPanel?
          wget: Unable to connect to remote host (127.0.0.1): Connection refused root@dreambox:~> wget -O - cPanel?
          Connection refused As you can see, it seems that Enigma does not accept connections on port 80.
          Just to prove the point, I have run (again on the DB) the following:
          root@dreambox:~>
          root@dreambox:~> httpd
          wget: server returned error 404: HTTP/1.0 404 Not Found root@dreambox:~> ps | grep httpd
          1012 root 500 S httpd
          1016 root 412 S grep httpd
          root@dreambox:~> kill 1012
          root@dreambox:~>
          This proves (I think) that the problem is not the access to port 80, but rather that the Enigma does not (for some reason) reply on this port.
          the dr.
          • Dr.Strangeluv
            • 6
            m8s, thnx a lot 4 your help, i finally solved this problem, check out:
            1) I have ssh to another PC running Linux that I have. At this PC I have run the command "script", which caused the PC to record everything I did from this moment to a file
            2) I then SSHed to my DB
            3) At the DB I issued the commands "killall enigma" and "/bin/enigma"
            4) After the enigma (many) startup messages, I did ctrl-C (to kill the enigma), exit (to finish the SSH with the DB) and another exit (to finish the recording caused by the "script" command).
            5) I then looked at the recording file, which contained all the enigma startup messages (I did it using vi, but you can use any editors). I looked for the string httpd. And - my oh my - I saw that the httpd was coming up on port 22 ! (for some darn reason...).
            6) I then did, at the DB, "wget -O -
            cPanel? and it worked !
            that's it 4 now and again, thnx 4 all the help!
            the dr.
