Best Image for Oscam
  • kopkidda
    • 122
    What is the best stable image to use on a Dreambox 500S for using Oscam, I dont want CCcam and Oscam together.
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    pli jade works fine m8
    • kopkidda
      • 122
      Ok thanks, think i have that at home somewhere.
      When I install this and want to get Oscam installed on its own, was reading on here that I have to install newcs and then manually copy Oscam on top of this?
      This sound about right?
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        the latest plijade has oscam in addons..so if you reflash with that, and only install oscam..you should be golden
        if oscam aint there; get newcs installed.
        download oscam
        then rename to newcs, delete file newcs in /var/bin/ and copy file that you rename to /var/bin/ then chomod its to 755. run newcs in yellow button.
        THEN
        Right click the file in your ftp program, select 'chmod' or 'properties' or 'attributes' depending on your program and tick the three 'execute' boxes so that the number changes to 755.
        Or
        You can telnet to the dreambox and use the 'chmod' command.
        For example,
        Code: Check this link
        chmod 755 /var/tuxbox/plugins/footy.so
        with thanks to DF and tieuyeu
        • kopkidda
          • 122
          Thanks for that,
          What is that footy.so?
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            its part of the telnet command.. dunno what it means..but df says it works so...........
            • kopkidda
              • 122
              Ok why do you need to run this?
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                you dont HAVE to.. its an alternative way to chmod
                • kopkidda
                  • 122
                  Ok slightly lost now, are you saying that I have to chmod 755 the Oscam file that I put in to replace the newcs file?
                  • Shady
                    Shite Link King
                    • Dec 2010
                    • 6404
                    yep
                    • mtv1
                      The Stig PT
                      • 4413
                      and then ??? what you talking bout mr. willis
                      • kopkidda
                        • 122
                        Ok thats great,thanks for yur help, will probably be annoying you when/if I can get it too work.
                        • Shady
                          Shite Link King
                          • Dec 2010
                          • 6404
                          ~~~~ no! dont ask me for help..i googled all that
