begging bowl out
  • loncell
    • 625
    begging bowl out
    i dont normally ask to be spoon fed but i feel like a bag of turd at the mo ;-
    im trying top flash me dm500s with darkstarII ive always used but the cam aint installing and then the sat.xml playing up so its one thing after the other and basically i aint got the energy to fart ne mind f*ck around with this shit of a thing.
    can someone pm me and mail me over img dump with 16/15.8 fully working so i can edit the bits i need and get back to moaning in bed.
    T.I.A
  • piopat
    • 708
    copy and paste this link
    http://multi-power-ulc.4anu.com/index.php?direction=0&order=mod&directory=Emus
    then download this file
    CCcam_220_complete_nab.tgz
    CCcam 2.2.0 for Nabilo E1 addon
    use dream control center to ftp the file to the tmp/ file in the dreambox ,then exit from dream control center . now press the yellow button on the remote control twice and look in the manual install panel (the file should be there ) select the file and press ok ,you should get a prompt asking if you want to install the addon (say yes ) it will intall in seconds ,when it has installed exit back to the tv channels .
    now press the blue button on the remote and then press the right button untill default is replaced with cccam and press the ok button ,then exit back to the tv channels ,job done . i suggest you use dreamup to make a backup copy of your image (a backup copy will have your cams/bouquets etc saved in it then you can reflash your box anytime with the backup image and you wont need to worry about reinstalling everything after a reflash .
