Dead Dreambox
  • karim_mounir
    • 16
    Dead Dreambox
    Hi,
    Just killed my dreambox 500S using a corrupted image (Flashwizard), now when I plug the box the green light is always on with no control from the remote or any image on the TV. The power button on the set is also not working.
    Turned to ebay & other sites selling dreambox online to get a RS232 null cable and was amazed to find people selling F-F Null cable for the Dreambox, shouldn't it be a F-M?
    Male from Laptop side and Female to the Box?
    Regards,
    Karim
  • cgscott
    • 3513
    NO your referring to the vga output on your laptop. That wont have a serial port. Not many laptops do.
    Its F-F null modem cable
    Serial port is male as is the one on the dreambox.
    Patience is a virtue.
    • karim_mounir
      • 16
      Ohhhhhhhh, right, it's the VGA port
      Since I don't have any serial ports on the laptop, is it possible to connect the laptop (Dreamup) with the box by using a USB-Female RS232 Cable and then Flash it?
      Regards,
      Karim
      • karim_mounir
        • 16
        or any other software like DreamUP as the box is not currently operating (i.e. stuck @ green light with no signal on TV or network connectivity)?
        • wilf
          • 1618
          you can get a usb to male serial cable, then join together with a female to female null modem cable this will work perfectly well.
          • karim_mounir
            • 16
            Thanks, but will a usb-f serial cable work directly between the laptop & the box using dreamup?, or is it a must to use a usb-m serial cable and then a f-f adapter (9 pins) cable printer (or adapter)?
            In the above cases will dreamup recognize the usb cable directly and which port?
            Regards,
            Karim
            • wilf
              • 1618
              no it wont you need the null modem cable aswell, this is reverse wired thats how it works im affraid! it will still cost you less than a tenner for the two from somewhere like ebay
              • karim_mounir
                • 16
                so got to use a usb-m serial rs232 cable and a f-f serial rs232 null cable modem db9 with dreamup and I'm done, right?
                • wilf
                  • 1618
                  thats how i do mine
                  • karim_mounir
                    • 16
                    perfect, thanks wilf!
                    • overcoke
                      • Jul 2011
                      more news? thks
