DM500 - 4.8e won't clear
  • southpaw83
    • 360
    Hi, got a DM500 which works great on most sats. However, after scanning 4.8e, nothing clears with my c-line (and it definitely should, other people on the same server clear on 4.8e). The clock also shows 3 hours fast on this one satellite only. The signal is good, and I can view the FTA stuff, but nothing else.
  • benny/9
    • 1964
    if your certain your on the correct sat and you can
    open fta chns like:- news 1, canal motor,english club,pb,pg
    alpha tv etc: with a good signal and your dish is big enough
    for the providers your line should open. and these chns have a good signal
    then i would first give the satellite a re-scan to see if that brings the
    chns in for you, if i remember right you need a 1.2 dish good signal from
    all tp's in all weather condittions. as for the clock have you set the right time zone
    in the box menu
    Please Read Carefully!
    • southpaw83
      • 360
      in the box menu
      I definitely get a signal on 4.8e. I have tried rescanning and still not clearing at all.
      With regards the time, it's funny as all other says show the correct time
      • SGTFlipFlop
        • Sep 2009
        • 1002
        I don't think it set's a time until it looks onto a channel and it set's from there
        • southpaw83
          • 360
          Really weird this, rescanned the satellite, but still nothing clears. I am totally perplexed
          • nathan2007
            • Jun 2011
            • 448
            try reloading a different sat.xml some sat xmls have 5e instead of 4.8e
            • southpaw83
              • 360
              Would that maybe help? Mine says 4.8e
