Is there any way to modify the remote controls so that I can control either DM500 which are located in the same room?
Two DMs in same room
Use the DB Switch plugin, it is usually part of the default plugins on most images. However you can find it here also http://www.digital-kaos.co.uk/forums...-dreambox-134/I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Thanks Paul. Only problem is that with the Gemini 4.2 or the 4.7, the "remote control" via web interface does not function. I can change channels, etc. with the enigma web interface, but am unable to, for example carry out transponder search / update... etc.Comment
PAUL
