Flashing questions
  • nature
    • Nov 2010
    • 144
    Flashing questions
    What's the best Image to flash on a DREAMBOX 500s?
    Also if there is a previous version , how do u delete it off the box? Or does it automatically be deleted?
    Final question, My box already has Pli-jade 2.2.1 Cam and Channels for 28.2e pre-loaded'' Is this any good? or is rubbish?
  • homer41
    • 207
    once you flash an image it overwrites the previous one, bit like installing a new version on windows on your computer.
    more than likely you want the box to unlock the sly package so i would stick with would you got.
    just update the channel frequency if they are old
    • nature
      • Nov 2010
      • 144
      oh thanks for that, How do u update channel frequency?
      • piopat
        • 708
        when reflashing a dm500s the new image overwrites the old image but the old image remains on the box ,a dm500s has a very small memory (which will fill quickly and can cause problems ) and so its wiser to flash erase before changing the image .
        when you open dreamup to flash the box look just above where you see flash and you will see flash erase (click on it ) dreamup will erase the current image in a few seconds and then you flash the box as normal .
        personally im not a lover of pli but each person has different views about images ,but as they say if it aint broke dont fix it .
        are you missing channels ? you can either add the frequencies manually with the remote or put an up todate satellite.xml file into var/etc in your box .
        • nature
          • Nov 2010
          • 144
          thanks again piopat for you great advice.
          There is channels already on the box. The free ones like channel 5 etc work. But sky sports etc do not work or any other.
          So after i go through var/etc, where exactly would I place satellite.xml ?
          lastly what is the best image what people tend to use alot?
          • piopat
            • 708
            if the channels are named in the channel list on the box but not opening thats down to your c line (if the channel names dont appear in the channel list at all then it would indicate that you are missing frequencies , you need to follow the advice i gave you in the pm . and once you have the channels opening as they should be we can add any missing frequencies .
            • homer41
              • 207
              or you could upload sgt flip flops bouquet
