As the title says to get the premium channels working I have to reset Cccam in Commando 14.3 everytime I switch the DM500 on after this they ork fine. Does anyone know a script or work around/reason for this. I have flashed several times, replaced Cccam several times and tried different versions. I really like the epg on this image and find it easy to use as it is just like my old Dbox2's so dont really want to try a different image if it can be helped. Any ideas appreciated ;-)
Have to reset Cccam in Commando 14.3 constantly
i had the same problem,
it was because i had the "load epg on startup" switched on, for some reason this knocked my cccam off.
press blue, then blue again and make sure this option is switched off.... -
i dont bother too much with it tbh...
sometimes will just do it manually, the missus cant reset the cccam herselve so i leave that option switched off.Comment
your box has been running out of memory during epg processing phase and cam has been be terminated so that the epg processing can continue. the reason this happened is because you have more channels in your process list than your box's limited memory can handle. you can either remove some unwatched channels from the online epg list until stability returns or you can try this memory overload patched version. this will stop and start you cam automatically before and after the epg processing phase.As the title says to get the premium channels working I have to reset Cccam in Commando 14.3 everytime I switch the DM500 on after this they ork fine. Does anyone know a script or work around/reason for this. I have flashed several times, replaced Cccam several times and tried different versions. I really like the epg on this image and find it easy to use as it is just like my old Dbox2's so dont really want to try a different image if it can be helped. Any ideas appreciated ;-)
extract the insatall.tar from the attached .rar archive and ftp this install.tar file onto your box into /var/etc/ folder. reboot box to auto install patched plugin.Last edited by LraiZer; 9 July, 2011, 17:11.Comment
