Flash Wizard Pro problem
  • mrblue
    • 568
    I am trying to flash an image using fwp 6.3 to my dm500. I have done it several times with fail, I have to unplug my dreambox and when I plug it back it it is frozen on the green jade pli image screen.
    Looking at this video I think there is a problem with my install, its not the same. When I select my image it gives me the prompt..."Sure to restore the backupped image jayjay.fw2"
    [ame="http://www.youtube.com/watch?v=GfkJeF2w2I0"]‪how to flash an image onto linux box with flashwizard pro‬‏ - YouTube[/ame]
    And 40 seconds into the video when its ticking off the steps, mine does not do this, it does another type of dialog box installing.
    On my last attempt, I even used an erase.img image via a serial null cable to wipe the box, then flashed with a working jade pli image using serial null. But this image Im flashing with fwp which is also jade pli I want to use this as the server guy has made it for me and has bouquets and epg and other stuff built in
  • the man
    • 1660
    did you match the ips? so its the same ip in your box as in the settings?
    try re name your file from jayjay to My_Flash_Image_Backup.flash
    on
    what does it say in the dialog box?
