dm500S wont let me edit cccam.cfg ?!?!?!
  • dave11674
    • 2025
    hi guys
    dont know if any1 else has had this problem
    my dm500s server is not letting me edit the cccam.cfg file
    i log into box with dcc also tried ftp
    download the file to my pc if ftp or right click n edit it in dcc
    i edited 1 line (deleted it)
    and clicked save icon
    it asked me if i wanted to replace it i clicked yes
    but when i reopen it the line is still there
    when doing over ftp
    it sais failed to create file
    any ideas
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  • Rodbouy
    • Jul 2010
    • 1320
    It might have went read only.
    Download the cfg from the blue button and it will overwrite it.
    The just add the cline again.
    Failing that you could try delete it with telnet then ftp a cfg file again.
    Or at worst factory rest and start again.
    • andy91
      • Aug 2010
      • 3583
      Was just gonna say download a new Ccam,take the crap out and add the info again.
      Rodbouy beat me to it.
      Andy.
      • Mjolinor
        V.I.P. VIC
        • 1093
        I am not sure if this is right or not but if you are editing /etc/CCcam.cfg it will not edit, it needs to be /var/etc/CCcam.cfg.
        I can't remember if that is a 500 or not but something is ringing a bell.
        Someone else will comment on that.
        • andy91
          • Aug 2010
          • 3583
          Can access ccam.cfg through etc or var/etc so dont think it makes a big difference,all i do is right click and view or edit.
          Andy.
          • dave11674
            • 2025
            thanks guys
            i think i will erase it completely and start again heheeh
            i am in the var/etc folder
            if it wipes it tho and wont allow me to put it back then im stuffed and family will be on the blowa to me hehehe
            oh well they will have to wait heheh
            if all esle fails ill wipe the box n do a fresh install.
            ccam 2.1.4 i have on there
            what lines do i exactly need in the main sever cccam.cfg file as ther eis lots in there and im not sure what i exactly need.
            i know its all hashed out
            but would be nice to get shut n just have in there whats important
            thanks for the good fast replies guys
            dave
            Tools owned.
            AVDI commander.
            Dashfixer orig.
            Dashfixer clone.
            Fiat km tool.
            Opel km tool.
            Ford KM tool.
            Op--com colne.
            Lexia & PP clone.
            • Mjolinor
              V.I.P. VIC
              • 1093
              Check the attributes then
              You need to open a telnet session and use "ls -l" to see the attributes, it may have been set read only.
              • dave11674
                • 2025
                here is a listing of my var/etc folder
                everythign looks ok
                i did manage to edit it earlier in ftp client mind
                dave
                Tools owned.
                AVDI commander.
                Dashfixer orig.
                Dashfixer clone.
                Fiat km tool.
                Opel km tool.
                Ford KM tool.
                Op--com colne.
                Lexia & PP clone.
                • MrFug
                  • 880
                  FTP is much easier than telnet anyway.
                  • Mjolinor
                    V.I.P. VIC
                    • 1093
                    Edit it using vi over a telnet session. It doesn't get anymore basic than that and if that doesn't work then I have no idea what is wrong. You could also copy it then edit the copy, delete the original and rename the copy.
                    You may find FTP easier but it is not as reliable and has a lot more layers of software, telnet and vi is as basic as it gets.
                    • Rodbouy
                      • Jul 2010
                      • 1320
                      If you download the whole config again from the blue button, it will remove and overwrite the old one. The edit the file and add your details again.
                      If this fails to work then you are better doing a factory reset.
                      • dave11674
                        • 2025
                        i bit the bullet guys n copied my cccam details to desktop of pc n formatted n reflashed the box
                        best way
                        dave
                        Tools owned.
                        AVDI commander.
                        Dashfixer orig.
                        Dashfixer clone.
                        Fiat km tool.
                        Opel km tool.
                        Ford KM tool.
                        Op--com colne.
                        Lexia & PP clone.
                        • southpaw
                          • 2233
                          why not right click > attributes > change chmod to 755
                          that should then allow read+write
                          • dave11674
                            • 2025
                            keep that in mind mate
                            dave
                            Tools owned.
                            AVDI commander.
                            Dashfixer orig.
                            Dashfixer clone.
                            Fiat km tool.
                            Opel km tool.
                            Ford KM tool.
                            Op--com colne.
                            Lexia & PP clone.
                            • dave11674
                              • 2025
                              hi guys
                              its doing it again
                              come to edit it last night and it will not let me
                              right clicked it
                              attributes are set to 644
                              so i click 755 and OK
                              i click refresh in DCC and then check the attributes again, gone back to 644 !!!!!
                              any ideas why its doing that guys ?
                              also can you copy me your main settings besides your F lines and show me how your cccam is setup pls
                              im leaving mine as standard and its got lots of crap in there i prolly dont need.
                              dave
                              Tools owned.
                              AVDI commander.
                              Dashfixer orig.
                              Dashfixer clone.
                              Fiat km tool.
                              Opel km tool.
                              Ford KM tool.
                              Op--com colne.
                              Lexia & PP clone.
