dm 500s home plugs vodafone dongle!!!!
  • chavslav
    • 99
    have a dell pc in bedroom, connected with wifi dongle vodafone 3gig a month..., have connected ethernet cable from back of pc, to home plug...
    with pc running, and connected to vodafone internet...
    in front room, have home plug, connected to dm 500s via ethernet, dm500s, will then be connected to 1 metre dish, has anyone got this set up working through a payg dongle,and does it work, or do i need a router, or somethingwifi on the dm to receive dat... as it stands i have devilo home plugs, and all lights are green at both ends, howing data, ethernet,power and so on, just wanted to know if theres any other equipment i need before i connect dish, thanks...
    1 metre dish,tm 5400ci super,tm 1500ci super,dreambox500s(currently a harsh learning curve)..
  • andy91
    • 3583
    Few have tried with limited success,think you will need a certain router for the job so let us know how you get on was looking at this for a mate a while back,will find you the link for the routers.
    Andy.
    • chavslav
      • 99
      cheers for reply, maybe a wifi bridge then on the dm , will that work??
      • chavslav
        • 99
        i have a feeling that my first post idea may work, as i was connected to x-box live last year through same method except the home plugs, vodafone dongle in usb, ethernet out off back of pc into x-box , and it worked,,,i was connected on internet and able to play with other gamers...
        • andy91
          • 3583
          Below are a list of compatible wireless USB dongles:
          Chipset RT73
          Alfa AWUS036s
          AftertheMac G54SL (Rebadged CNet dongle)
          Asus WL-167G v.2
          Belkin F5D7050 v3000uk
          Belkin F5D7050 v3001 & v3002
          Belkin F5D9050 ver 4000uk \
          Buffalo WLI-U2-G54HP
          Conceptronic C54RU
          D-Link DWL-G122 Rev. C1 (F/W.:v3.00)
          D-Link DWL-G122 Rev. C1 (F/W.:v3.10)
          D-Link WUA-1340
          Edimax EW-7318USg
          Engenius EUB-3701 EXT
          Hama 00062764
          Hawking HWUG1
          Hawking HWUG1A
          Hercules HWGUSB2-54-V2
          Hercules HWGUSB2-54-V2-AP
          Linksys WUSB54GC
          Linksys WUSB54GR
          MSI US54SE II
          Ovislink W54USB v. 2
          Ovislink WT-2000USB
          Quickertek Quicky Jr
          Sitecom WL-113
          Sitecom WL-172
          TP-Link TL-WN321G
          Chipset ZD1211B:
          Trendnet TEW-429UB C1
          ZyXEL G-202
          Check out the thread below,Andy.
          • chavslav
            • 99
            does the wifi dongle connect into dm box??
            so i keep my payg vodafone one in pc and just put one in dn box then??
            • southpaw
              • 2233
              The wifi dongle is an option other than home plugs, (but will need an wifi router to connect to, if you got internet connection sharing enabled on the PC, then in to your home plugs that's all you need, no wifi needed as you sending data over your mains circuit,
              • chavslav
                • 99
                ok, think i've got it, i have payg dongle,but 2 home plugs from pervious installation with an incoming bb conection with router.
                , if i have my payg dongle, which is wifi, and have internet connection shared, wll i then send signal down ethernet port on back of pc, into home plugs, or will this not work, can't see where the wireless 3g router comes in unless my vodafone dongle goes in that, then ethernet out to home plugs!!!!!
                would that be right?? thanks
                • andy91
                  • 3583
                  On a standard set up with homeplugs you have one homeplug plugged from mains into router via ethernet.
                  Other homeplug is then from mains to dreambox via ethernet.
                  Andy.
                  • southpaw
                    • 2233
                    Andy.
                    yes , thats right andy , but the router is just pumping internet into the homeplugs via the ethernet cable ,
                    A ethernet cable from pc (with internet sharing enabled) would surely output the same kind of data connection out as the router would ,
                    Or am i missing something obvious here ???
                    • andy91
                      • 3583
                      He hasnt got a router ,well the correct one for a dongle
                      Andy.
                      • southpaw
                        • 2233
                        Andy.
                        andy, i know he hasnt got a router , i was just generalising , saying that homeplugs work from a router by using the ethernet out connection ,therefore same type of connection/data transfer as the ethernet out on pc (with enabled i-s)
                        • chavslav
                          • 99
                          well we see how it goes, one pc, one wifi vodafone dongle,2 home plugs one dm500s, and a 1 metre dish. going to enable internet connection share ,on pc eterne intohme plug n bedro, then ethernet out into dmbox, in front room... nice weather the day to do it, thanks for the advice people, oh andy will the 3g router you speak off will that increase the wifi connection then, there is no hard wired broadband into property so i'm assuming this router you speak off is for this type of wireless set up..???
                          • reddevil157
                            • 1427
                            Dathai55 did a tut on this somewhere on here, can't find it now, but I'm sure this is the router he used.
                            • chavslav
                              • 99
                              ok so i needed to find out the hard way, there is no facilty in D C C, to apply an ip adress to a dongle only a router, which means all the above now makes sense, a wireless router WITH VODAFONE DONGLE in it, will obviously give me an ip address, unless theres another way any tips???
