image problems, gemini ,pli jade,darkstar 2..
  • chavslav
    • 99
    had all these 3 images on dm500s clone at some point in last 2 days, gemini wouldn't connect to servers , even though cccam was present 2.2.1, there was no cccam.config file in dcc, so erased, put on nabilo darkstar 2, cccam 2.2.1 and 2.13 cams would not save in addons menu, tv showed, ci (common interface only.. and no cccam.config file in dcc, again...
    so found pli jade maxvar,very dark and green not to keen , downloaded cam after much needed sodding about, once again,no cccam.config file, in dcc and i don't know how to load cam in dm menu nabilo just wouldn't save it, help needed before it all flies out the window...
    erased that, installed pli jade maxvar( very dark and green skin)
    1 metre dish,tm 5400ci super,tm 1500ci super,dreambox500s(currently a harsh learning curve)..
  • Staminastan
    • 44
    Persevere with PLI Jade Maxvar - download CCcam via Menu / Setup / Software management / Downloads... / SoftCams and CCcam config. Do a service scan or download and FTP over via DreamBoxEdit SGTFlipFlops' excellent bouquets set via the sticky and bingo
    • pogo2009
      • 45
      When you download make sure you download both the cccam file & the config file
