what emu plugin do i have installed
  • bikermike
    • Feb 2011
    I am new to using my dm500 it already had nabilosat v 0.8 and cccam 2.0.11 installed before I started using it. I'm pretty confident using Dreambox Control Center to ftp to the dm500. How can I tell what emu plugin has been installed on the box ie I need to know which of the following is currently on the box Evocamd, Newcamd, Radegast?
  • MrFug
    • 880
    Didnt you say it had cccam on it? Enter your softcam menu and you should see a list of installed cams.
    • bikermike
      • Feb 2011
      Thanks for your advice when I go to the Nabilocam Blue Panel menu it states there are 2 cams installed Common Interface and cccam 2.0.11. Does this mean I have to manually install Radegast or Newcamd??
      • mdt
        • 3034
        you dont have to manually install any other cam if c**am 2.0.11 serves your purpose, if you need radegast or newcamd then go to the addons menu and download one. if the addons server doesnt work then you can go to the downloads section of this forum and either flash a new img or add the tspanel or somthing similar to get what you need. regards mdt
        • bikermike
          • Feb 2011
          Hi MDT
          Thanks for your help. I am still trying to understand linux based stb's. I now realise that c**am 2.0.11 is the only emu I need for my purpose I manged to prove this by viewing Mezzo TV and TV Globo on 13 degrees after uploading an upto date magic file to my dreambox. I have a motorised 1.1 metre dish and when trying to view bulsat 39 degrees east without cs my tv displays the following message c**am 2.0.11 cald 0xffff Address: Hops 0 decode:unsupported cas ecm time 0.000. I would like to view bulsat, your help would be much appreciated.
