help with dreambox 518s???
  • ade786
    • Aug 2011
    • 98
    hi guys, can you cccam with dreambox 518s?
    if yes is the same way as dreambox 500s?
    thanks in advance
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    yes
    • ade786
      • Aug 2011
      • 98
      Originally posted by shadyback
      yes
      can you use dreamup to flash it? also whats different from dreambox 500s to 518s?
      • tony2803
        • 266
        same as 500s m8,i have had one and worked totally same as 500s,the only difference is the model number 518s..
        • ade786
          • Aug 2011
          • 98
          thanks, but ive read in mmany other forums that it doesnt read a card?
          when you cccam with that do you need to put the s*y card in or not? sorry for the nube answer :S
          • gsmtech
            • 264
            518s has internal power supply and does not have scart socket. I would say avoid the 518s they are rubbish.
            If the internal PSU board fails, it's not easy to locate a replacment. Power supply failure is probbaly one of the most common failures on STB's
            So get a 500S instead at least the PSU is external easy to get a repalcment off fleebay etc if it fails.
            A 518s should still read a card ok, You only need a card if you want to share that card out, or if you have a subbed card which you want to use with the box. If your getting your channels via CS for another source you dont need a card.
            • josh1e
              • 5
              Hiya mate.
              518s does NOT have a card reader. you can only use CCcam as a client or to reshare. The 528s is the same. internal PSU and no card reader. the DM500s has the card reader.
              how do i know? i have one!
