dreambox 500s ethernet connection help!!
  • ade786
    • Aug 2011
    • 98
    hi could you please help me with 1 question, well i had a dreambox 500s and the only way it connects to internet is when you keep it in the fridge for a good hour, but now it connects for 2 minutes, then stops the connection, i can see the ethernet light flashing inside the box, then it connects for 2 seconds then dies out
    please help! as i have bought a 12 month c line
  • cgscott
    • 3513
    Try another power supply. Why would you stick it in a fridge?
    Anyway try another power supply. Does it boot up ok etc? Is it just the LAN that is failing?
    Patience is a virtue.
    • smirnoff_rules
      • 8603
      its going to cost more that getting a new one m8 , sounds like a dry solder joint to me , l would take the board out and look for joint , if u cant see it u could put board in oven wrapped in foil for 20 minutes ,, works on car ecu's and iphone boards ?
      • ade786
        • Aug 2011
        • 98
        @cgscott i have tried another power supply and it booted up okay but still didnt connnect
        @smirnoff_rules which joint? the one from the ethernet port to the actual board? hmm, dont you think that will mess up?
        thanks for your input guys
        • ade786
          • Aug 2011
          • 98
          apperntly ive heard that if you get a image from a working dreambox 500s and use that image to flash your own dreambox that might work?
          any one going to lend me a working image with CCcam?
          • davvo
            • Apr 2009
            • 666
            can you ping your box
            • cgscott
              • 3513
              If your LAN is gone then nothing will work. Most images have cccam already in them.
              I have a 500s here that the lans ~~~~ed on. NOt even looked at it to be honest.
              • ade786
                • Aug 2011
                • 98
                by ping you mean? :S sorry i am a noob
                • ade786
                  • Aug 2011
                  • 98
                  my internet is working, i have connected my pc using ethernet and using laptop which is running on wifi
                  and need to get it sorted asap,and can you put your dreambox in the fridge for just over an hour and i will work, try it mate
                  • cgscott
                    • 3513
                    No. I have one running. Can you ftp to your dreambox?
                    • ade786
                      • Aug 2011
                      • 98
                      nope, i used dcc to find out the ip got the ip and looked on the dreambox and the ethernet was dead, i was able to ftp like a few days ago, but i couldnt use it as my remote is dead, and checked today and it was frozen
                      • cgscott
                        • 3513
                        Maybe turn the temp down on the fridge if its frozen
                        On a more serious note it does sound like a board problem. I would either get someone to look at it or buy a new one.
                        • ade786
                          • Aug 2011
                          • 98
                          dont know what the temp is on the fridge , and yea it probz is, might just get a openbox s10 next, cheapest hd receiver
                          • mtv1
                            The Stig PT
                            • 4413
                            cheapest yes they are that although a dm800hdpro is getting cheaper and a way better box worth the extra few bob imo
                            • ade786
                              • Aug 2011
                              • 98
                              rather stick with a openbox
