DM500-S "-sh: ipkg: not found"
  • magnifor
    • Oct 2011
    • 4
    Hi Folks,
    I want to try a ipk package trough telnet. When i try to install it i get the following error:
    After some searching i also tried opkg, the same error:
    -sh: opkg: not found
    So how can i install the ipk pacakge? Thanks for your time and help.
    I have a clean Gemini 4.7 installation.
  • cokesux
    • Nov 2011
    • 34
    As you see, the 500- does not use ipk's. I guess there's a slight possibility of the app/plugin/etc. working if it was for an OpenEmbedded Enigma1 box (500+, 600, 7020), but if it was for an E2 box (800, 8000, etc.) it's highly unlikely as they use completely different processors...
    That said, ipk's are generally ar compressed "archives" that contain a tar.gz (among other things). If you can extract using ar, then the tar.gz shouldn't be much of a problem.
    Newbie My ASS...
    • magnifor
      • Oct 2011
      • 4
      I want to install cccam with a proper cccam.cfg file. CCcam 2.2.1 i have installed manually, but i don't have a cccam.cfg now.
      My idea was to install TunisiaSat Addon Manager so i can install cccam with a cccam.cfg file. Any suggestions? Thanks
      • davvo
        • Apr 2009
        • 666
        there is a blank cccam cfg file here
        you need to unrar/unzip it then look in the folder its in there
        then ftp it to var/etc on your DM
        http://www.2shared.com/file/4yebFGPh/cfg.html
