Can we install more than one instance of Mgcamd in DreamBox DM500S receiver?
I have mgcamd, cccam and rqcamd on my DM500S now and I can select which softcam I want to use by selecting the Default SoftCam from the Softcam setup screen.
I have 3 or more different server connections in each of these softcams and they should fail-over if one of the servers are down - but if the server is overloaded and seizes it doesn't release the users to fail-over to the next server in the list. The only way to get out is to select one of the other softcams and do a "Save and restart cam".
Instead of using Cccam and rqcamd as the other softcams I would like to use 3 different instances of Mgcamd - is this possible.
With rqcamd you can rename the rqcamd program and its config file to any name you want - so you can have several different installations.
I haven't seen any options where you can rename Mgcamd and its config files to anything other then mgcamd and newcamd.list.
