Hi all
DM500s and Darkmotor motorised setup.
Everything was working fine until I decided to try a different image.
After erasing image and then reflashing with various images the latest one Nabilosat darkstar II image, I could not get the motor to turn but it will turn by manually pressing E/W buttons. I have factory reset the box and reset the motor but everytime I try to set up the motor by entering LAT and LONG the lights on the motor go out when I go to the next page of setup and also everytime a signal is sent to the motor, and I have to reboot to get the lights back on.
The motor has been tested and it is OK. Using a meter the power goes from 10v to 17v when I send a signal to the motor which I think is OK. If I bypass the motor I can receive channels.
I unfortunately did not backup before flashing...lesson learned!
Am I missing something? Do I need to install anything else apart from the image? a service list maybe?
I have tried other forums with no luck...maybe this time?
Any help would be greatly appreciated
Cheers
Cheers
