connecting via null/usb2
  • mapex
    • Jul 2010
    • 209
    DM500s
    Got a new acer i5 and could not use the norm
    cable to flash it, aquired the adapter to usb2
    but had connection failure again and again.
    Looked around and tried to flash it for the 1st time
    using FTP and telnet, i FTPd the image to the box
    used telnet of which im a novice to do the next
    bit following instructions on line, i watched as it
    earased the image then it stopped.
    Now i cant get the ip back, tried dcc to search looked
    like it was going to connect then failed..kept at that
    for a while, tried plugging into my tv to see if it had
    any setup nothing, tried a new power lead.
    Can someone tell me the right move to make now.
  • psats
    • 823
    here
    plus you will need usb serial converter.
    • smoggie
      • 863
      yeah its a bit hit and miss ftp image, rename image root.cramfs and manually update. I have a quite a few bad flash this way. Reason i keep my dell c610 is that its got com port, priceless as them usb serial converters can be a pain apparently
      • mapex
        • Jul 2010
        • 209
        Got and old pc down from my loft, 128ram...BUT it did the job flashed commando image got it back up and tunning.
        Dreamup noticed it in seconds...
        • alladdin
          • Oct 2010
          • 72
          i was having issues with conection via usb. i found a post on here recomending com 3 and a lower transfer rate, worked like a "dream".
          • psats
            • 823
            you only have to look in device manager to check the port or change it to the one you want.
