dreambox 500-s need help before I run the box over with my truck.
  • slapass
    • 4
    What image can I use for dreambox 500-s without the use of a card, I herd I can use this like a coolsat or others with out the card. and what all do I need to get this running.
  • despdan
    • 544
    read the stickies in the cable section this will get you going in the right direction. then when you have a specific question post it back here. they will help you about Images cams rom & keys
    • slapass
      • 4
      I have Sat not cable, can it be done with out card?
      • despdan
        • 544
        I know you have sat but there is more info on setting up this box in the cable section it doesnt care if its cable sat or terrestrial box there set up exactly the same Images roms cams & keys.
        • slapass
          • 4
          Thanks I will look at it.
          • slapass
            • 4
            dreambox 500-s I can't get it to work
            dreambox 500-s I can't get it to work, I tried all of the images, can I get it to work with out the any card at all.
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              Use the nabilosat darkstar image. Connect the dreambox to your router to give it internet access. Download CCcam 2.0.11 from their addons menu and install.
              The only way to get channels without a card is use a cardsharing server. We don't allow cardsharing discussions on this board so google is your best friend in that department. Cccam is the emu that connects to the server and you get your keys over the internet.
