to begin the story, I have DM500S box. It came with PLI jade image and loaded with all the settings and works perfectly. the problem is I cannot access it, I do not know the root password I tried to install Tuxbox but with no luck. the box is closed in a way I cannot install any add-on manually nor automatically. I cannot even open software management as it gives me a message that it is not possible to install anything. I also cannot upgrade as it says it cannot find Http://myserver.com..... What I did is that I created a shared folder in to my pc and mounted the VAR folder in the dream box to this folder. I was able of course to edit the passwd and changed the root password but the problem is that all the channels stopped and to make things worse I was not able to return the /VAR folder to the internal flash. Whenever I try to select Internal flash I get a message saying that the box need to be reboot but after it boots up I find that the shared folder in my pc is mounted to /VAR. I tried to force unmount the /VAR but when the box boots up it cannot find any settings and starts with the wizard asking about the display and the satellite settings. Please help?
Also is there a way to backup the system and the settings, I do not want to lose more settings.
Any suggestion would be appreciated.
Thank you
Thank you
