dm7000s. ERROR flash erase failed
  • citydays
    • Mar 2012
    • 5
    help needed ..with dm7000s ...when trying to flash using null modem i get ..( ERROR, flash-erase failed, box will be unusable now!!) ......so i tried to use (erase.img) file to clean up every thing and start again didnt work i get ..(error Found no valid jffs2 in image flash-erase not supported!)... tried with different versions of dreamup still box lcd stuk on orange display with dm logo ,out put to tv black screen .tried to up load the original image for box still no joy ...>note box never been flashed before had the original enigma on it before this and was 100% working <. ....does any one know how to resolve this error or whats causing it .thanks
  • Bann32
    • Oct 2011
    • 518
    I just had a quick look around, repeat the flashing of the flash-erase a couple of time.
    Are you using the right flash erase? As I would suspect that the flash memory is larger on the 7000.
    • citydays
      • Mar 2012
      • 5
      thanks for the reply bann32
      i have tried more than 30 times with the flash erase put getting the same error.(error Found no valid jffs2 in image flash-erase not supported!) i am pretty sure its the right file..iam sending u copy of the erase the file to check just in case.....any other ideas.....thanks for ur reply
      • tahamtani
        • Jul 2011
        thank you very very much
        • tahamtani
          • Jul 2011
          thank's for all times
          • phat1
            • 114
            hi did you sort out your problem as i have the same issue?
