HELP - how can i remove pin from dm500??
  • hardy27
    • Oct 2011
    • 47
    can anyone tell me how to remove parental lock/pin from dm500, as there is an existing pin lock on already?
    dont want to reflash the box because i will lose cl*ne and setup.
    can i change pin via desktop/pc??
    thanks guys
  • davvo
    • Apr 2009
    • 666
    with
    DreamBoxEdit
    to get the existing pin
    fire up DreamBoxEdit
    fill in your details in options and save
    then click ftp
    click receive files from dreambox
    pick a channel thats locked in services on the left hand side
    right click it
    click show/edit details
    there you will find the pin
    disable it or enable it
    or change it
    you can only receive files from the dreambox
    if you know the dreambox password
    • hardy27
      • Oct 2011
      • 47
      Davvo
      i meant the pin for the dreambox...not the channels.
      i.e. if i wanted to go into setup on dreambox, i need a 4digit pin number. thats what i need
      • davvo
        • Apr 2009
        • 666
        in 1st post you say remove parental lock
        look 3 post down
        • hardy27
          • Oct 2011
          • 47
          davvo wheres post 6 can you paste link
          cheers mate
          • hardy27
            • Oct 2011
            • 47
            oops got the link
            • davvo
              • Apr 2009
              • 666
              for dm500
              start DCC click telnet and paste this line in
              cat /var/tuxbox/config/enigma/config|grep -i pins
              look for this line
              setuplock=
              find last 4 digits on that line
              then go here and it will convert them
              and show the pin
              Hex To Decimal Converter
              if you cant use telnet
              fire up dcc and goto
              right click edit
              and look for setuplock=
              and convert them as above
              • hardy27
                • Oct 2011
                • 47
                top man davvo
                it worked mate thanks
                • nabz khan
                  • Sep 2012
                  • 5
                  i have this same problem were do i get the dcc file but in English i downloaded 1 but its not English also to use this software do i have to have a serial to usb connection to my pc ?
                  • nabz khan
                    • Sep 2012
                    • 5
                    IV GOT THE DCC TO WORK BUT wen i try to reconnect it says dreambox has no ip adress that am i doing wrong
