Problem with my DM500 S PLI IMAGES Box?
  • Caffieine
    • Apr 2012
    • 8
    Hello guys, Since 5:00 my DM500 S PLI IMAGES has been not showing up channels. I called a guy who works for them who hooked it up, he told me to reboot it.. go to a channel see the agc.. snr.. they were working fine, he said he does not know.. I researched how, and I found this beautiful forum. No Channel is working, how do i fix this?
    I rebooted my Dreambox... did so many things but it did not work
  • mast
    • Nov 2010
    • 1027
    Might sound daft but try a different psu if you got one. If not then maybe a rescan or reflash but I would defo try another psu first.
    If you gonna reflash make sure you do a backup of the image via dreamup or at least make sure you got the cline info saved.
    Regards
    Regards
    • Caffieine
      • Apr 2012
      • 8
      Do you mind explaining that in a different kind of way? I contacted support again, they keep asking me questions and then they hang up. I need this fixed quick.. Thanks
      • smoggie
        • 863
        do you get any free to air channels?
        • Caffieine
          • Apr 2012
          • 8
          not at all, no channel comes, i think it might be a problem with the reciever, cause i called support AGAIN and they told me to stop calling, and get the thing replaced
          • mast
            • Nov 2010
            • 1027
            As I said try a different psu (power supply unit) I had one recently box would boot up normally but no channels.
            Scanned and channels shows but as soon as I reboot channels have gone so loaded up a working channel list and its gone as soon as I reboot.
            Changed power supply and everything fine, these power supplies can cause different problems as soon as voltages drop the slightest..... so try a different psu first and then take it from there.
            Regards
            • gji25
              • Feb 2010
              • 353
              if youve tried a different psu and its the same then its your tuner thats at fault
              dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
              • mast
                • Nov 2010
                • 1027
                Agree with the above poster if psu doesnt solve the problem then its the tuner, come back and tell us if you resolve this so its helps other people if they have a similar problem.
                Regards
                • MR C
                  • Apr 2012
                  • 19
                  i had this on mine the lead from the dish waz not pluged in took me all day waz right p off
                  • mast
                    • Nov 2010
                    • 1027
                    We`ve all done summat daft like that at some point.
                    • ken9
                      • Feb 2010
                      • 52
                      same problem with my box
                      hi there im having the exact problem ive tried 3 different images i can only get some channels ,strange
