Trouble with DM500S
  • Grimbo84
    • 27
    Trouble with DM500S
    Hi guys having trouble with my box..its been working fine for over a year no problems..the last week i havent been able to poick up my premium channels i still recieve FTA channels...i can connect the box to the internet i have checked that..i got a no ip address a 2 weeks ago but im not sure if i used since then?also when looking at the CAM.CFG i noticed there was a folder above say NO.corefiles(0) with nothing it..it might have always been there but i have never seen it..so i dont know what is wrong but im sure at least one of you legends of kaos will have a idea cheers
  • Rodbouy
    • Jul 2010
    • 1320
    looking /var/etc/CCcam.cfg
    also check with who you get the specials from as i take it they are not your own.
    • Grimbo84
      • 27
      yep they are fine as i have requested new lines(i know they are legit as i have had them for 4 months+)..and they dont work either..in my cam.cfg file there is only that cline..should there be any other text?(there is a line above saying connections?)
      Is that file "no.corefiles" supposed to be there then i take it?
      • Rodbouy
        • Jul 2010
        • 1320
        download cccam pppanel and see if they are connected.
        Also got softcam setupand save and restart cam
        • Grimbo84
          • 27
          thanks for your help where download that from?
          • Rodbouy
            • Jul 2010
            • 1320
            try the download form the box.
            Its in the pli download section.
            Prob be varients depending on what img your running.
            • Grimbo84
              • 27
              ok m8 i have downloaded that how do i access it?
              • Rodbouy
                • Jul 2010
                • 1320
                yellow button for plugins
                • Grimbo84
                  • 27
                  ok m8 done that went into servers.. it has the cline in there.. there is a blank space below the bit that says connected if you know what i mean?
                  • Rodbouy
                    • Jul 2010
                    • 1320
                    If it says connected then its possibly ure end, did you save and restart cam ?
                    • Grimbo84
                      • 27
                      yes i saved and restarted cam.
                      what else co i do?all that should be in the cam.cfg file is the cline right?
                      also in network both boxes have to be ticked(DHCP)
                      • Rodbouy
                        • Jul 2010
                        • 1320
                        Your network is fine or it wouldnt have let you download the ppanel.
                        lines in CCcam.cfg located in /var/etc
                        Give them to a mate to test and see
                        • Grimbo84
                          • 27
                          yes checked this morning lines working..anything else to check?
                          • Rodbouy
                            • Jul 2010
                            • 1320
                            So they work in mates and not in yours?
                            Only thing left if factory reset and start from scratch?
                            • Grimbo84
                              • 27
                              so would i have to flash my box?i got my box already flashed..i wouldnt know what i would need etc?its strange that it worked fine only a few weeks ago?
