setting up dm500s
  • cboyer
    • Feb 2012
    • 271
    setting up dm500s
    hi peeps please can someone help me set up my dm500s? i can't even get freeview channels ?
    "I've got it made. I've got a wife and a TV set -- and they're both working."
  • badapple
    • 2041
    Ok, tell us what you have done so far...
    Have you flashed it with an immage?
    Is it connected up to satellite dish proper?
    Are you getting anything?
    more infor please
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • cboyer
      • Feb 2012
      • 271
      hiya mate i aint flashed a new image yet it is the satelite searching im stuck with channels are usually 28.2e but i only seam to find stuff on hotbird 13 the image is the 1 with snakes the game on etc dont know exacly which it is? i am set up to dish correctly as i have set up my dm800 and openbox fine
      • Murf22
        • May 2012
        • 50
        you didn't say if you have motorised dish:
        if you have motorised.. do you get reception on 28?
        if not.. what channel does it find? if it's the uk channels, do a factory reset so the initial setup comes up and select 28 as your default (and only) satellite
        ..if the channels are foreign you may need your dish moved
        • cboyer
          • Feb 2012
          • 271
          no don't have a motorized dish i will try doing a factory reset m8 and i don't seam to get any channel on 28 just the uk ~~~~ ones shopping etc on 13
          • freck
            • 1076
            Goto setup/satellites and transponders/satfind and report back your AGC and SNR %'s.
            Be sure your setup to receiver 28.2E single sat/lnb if your on a static dish.
            Freck
            • cboyer
              • Feb 2012
              • 271
              sorted it m8 did a factory reset and went through settings again cheers pal
