pink screen/powering off
  • irishtoon
    • Feb 2011
    • 5
    hi guys i have two dm 500s here flashed them both tonight(i have flashed other boxs at least 20 times before) but since i flashed these two i cannot get them to work, on one i go through the start up settings as far as the tuner setting i select my dish type and select auto tune and bank the screen goes pink with lines through it and the power light on the dm500s goes off on the other i have got as far as searching all the channels but when i select one i get the same pink screen and box power going its hardly the tuner on both box's? as these two boxs are new well no more that 3 months old and very little use,
    any help would be great
  • mtv1
    The Stig PT
    • 4413
    you tried a different image the one your using might be corrupt also are u using the same scart to setup both always the small things
    • irishtoon
      • Feb 2011
      • 5
      yea i changed my image really need to change from gemini always seem to have problems with them ill try the scart now ment to do it a while ago but that would hardly cause teh dreambox to switch off would it? thanks for the reply
      tried the scart didnt help same thing
      • mtv1
        The Stig PT
        • 4413
        ya gemini to my knowledge is unsupported try pli jade i have some easy images if you need them
        • mast
          • Nov 2010
          • 1027
          Are you using the same psu on both while you are flashing and setting up, if you are then try different psu.
          Regards
          • mtv1
            The Stig PT
            • 4413
            Originally posted by mast
            Regards
            psu {power supply unit } to my knowledge if faulty will not allow flashing believe me i know most likely a bad flash and he has flashed before
            • mast
              • Nov 2010
              • 1027
              Hi mtv
              I have flashed before with faulty psu (think it might be dependant on what sort of voltages its dishing out when faulty) and then would stick on setup stage or just the pli screen and wired colors as well.
              From my experience I would say thats a classic psu fault but not dismissing what you are saying cos it could quite easily be a corrupt image/bad flash so maybe download an image from a different source and try again.
              Regards
              • irishtoon
                • Feb 2011
                • 5
                hey lads thanks for the help i two faulty new psu's not good anyway boxes are working thats the main thing
                • mast
                  • Nov 2010
                  • 1027
                  So are you saying both the psu were faulty and now with new psu boxes are running fine, just so its clear for other people who experience similar problems.
                  Regards
