Flashing query
  • cubix
    • Mar 2010
    Flashing query
    Lads
    ITs been a while since I reflashed the 500s and have since lost missed placed the usb/null cable, on top of that all the pc's in the house are running Win7.
    I seen a post regarding flashing the 500 just like the 800 via the ethernet cable. The problem I am having is that when I hold the power button before power turn on I cannot get the 500s to got into stop mode. Anything else I can try as it will be a royal pain to organise flash via null cable.
    The reason I am thinking of flashing is that I seem to be missing the ccam config file when i ftp into the box. Can some confirm where this file normally is. The image is the darkstar 2.
  • mark8393
    • 2305
    cccam.cfg goes in var/etc. if missing just use dcc to add it to box, no need to flash.
    • gji25
      • Feb 2010
      • 353
      just open a new text document and name it CCcam.cfg then save it. paste your line in there and save. then ftp it to your box
      dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
      • cubix
        • Mar 2010
        Cheers lads, have copied the CCam from the 800hd into the 500s but still only decyrpting FTA channels. Could this image be missing something else
        • mast
          • Nov 2010
          • 1027
          Hi
          Cam might need to be installed as not all images have it preinstalled and Im not sure about darkstar.
          Also if you have copied the 800hd CCcam have got both boxes running at same time with the same sea lion info or have you edited with another sea lion for the 500.
          Are your network settings correct. Just a few things for you to check.
          Regards
