help breambox 600 pvr satellite configuration
  • Jerrym
    • 4
    Hie guys. I am setting up my db I have just obtained and I am raw. I have gone up to the satellite configuration - non-standard user defined configuration and I am supposed to choose a satelite. Now the problem is I do not know which one to choose. I want to use s*y sat, and it is a basic one currently subscribed card to view channels as I get to grips with this toy and then may later when I know whats going on buy a proper sat dish. I have imaged (GEMINI) and flashed its it was all good to go, connected to the LAN and so forth.Thanks guys. P/S please provide an idiot guide, 'I wont mind'
  • Sicilian
    • 168
    You need to select one single satellite & asta 2b.
    D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
    • Jerrym
      • 4
      db 600 pvr using s*y card
      Many thanks. Just to confirm it could be any satellite from the many that were displayed? Also do you have any recommendation as to the better satellite I could pick. I can confirm I have seen astra 2. What about the cccam and new cs - where can I get these as which file should I download. I have already flashed with gemini and it has cccam 2.10 or something. Thanks agaim mate for your help.
      • Curious123
        • 2591
        If your dish is motorised than you could select 'non standard' or 'many satellites' and then tick the usals options.
        • Sicilian
          • 168
          From the setup you've described (fixed sky dish), you'll only be able to use the settings I posted.
          CCcam is the cam you need you using a subbed sky card in your box or if your want to card share. Now card sharing discussion is not allowed here.
