QUESTION FROM AFRICA
  • Ahmad
    • 14
    HELLO MY SENIORS I LIVE IN AFRICA ,IAM A NEWBEE,I HAVE A DM500S, I HAVE DOWNLOADED DARKSTAR 2 IMAGE THEN I GOT STUCK,CAN SOMEONE OUT THERE TELL ME WHAT TO DO PLS STEP BY STEP? I HAVE INTERNET. MY FRIENDS ARE TAKING A BET THAT I WILL NEVER GET THE DM TO WORK LIKE YOURS OVER THERE B/COS IAM IN AFRICA . PLS HEEEEEEL P
  • 2tone
    • 483
    hello ahmad this is the cable room if you have a sat dreambox you need to post in the sat room might need a mod to move it there
    • caveman_nige
      • Feb 2008
      • 4920
      Thread moved from cable section to satellite section...
      Admad please can you write/type in lower case, thanks...
      • westkill
        • 2378
        what satelittes you trying to get
        what dish setup you got m8
        • Ahmad
          • 14
          hi guys, sorry for the mistake- a newbee- I have nilesat, hispa and eutel w2 dishes.. thanks
          • westkill
            • 2378
            are both your dishes connected via a diseqc switch to your dreambox
            • 2tone
              • 483
              need a bit more m8 do you have a motor or a fixed dish set up
              • Ahmad
                • 14
                additional infor, iam using three dishes all connected via a diseqh,single lnb on each.
                • Ahmad
                  • 14
                  No motor, just fixed
                  • .: JaCkPoT :.
                    Retired Sat TV Addict
                    • Aug 2008
                    • 5607
                    Is there any specific channels your after?
                    ___________________
                    In the good old days, I had
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    90cm FortecStar dish
                    Maxx 110cm Dish
                    Technomate 2300 Motors
                    • .: JaCkPoT :.
                      • Aug 2008
                      • 5607
                      Well if your after nilesat then there is two main ways to open the encrypted channels, ie,showtime,art..
                      The main way is to buy a i2 card and a cas 3 programmer and keep the card up to date.this will cost about 80quid..
                      The other main way is by cardsharing however google is your friend for that not us..
                      The channels use to be available by latest key files but that is becoming more of a lesser occurance as days go on..
                      ___________________
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      Maxx 110cm Dish
                      • Ahmad
                        • 14
                        evening sadiq, thank u for your attention,can u pls tell me the next thing to do after downloading darkstar 2 image? like which cam to download etc. pls bear with me iam in AFRICA. thanks
                        • krazylegz
                          • 2834
                          connect your box to the internet and use the addon server within the image m8....think its yellow then yellow again....download CCcam, but you will still either need a official card or 3rd party card/cam to view the encrypted channels, or alternatively join a cardshare.
                          PS3= krazylegz120282
                          • uk_rules_ok
                            • 4
                            I cant see any reason why you shouldnt be able to get it working, if you use cccam 2.0.11 with an original card you should be able to view encrypted channels, also bare in mind that some cards need cccam + newcs to read the card m8. if the card is nds3 you will need to mod the voltage on the vcc with a 18ohm resistor and a 4.7v zenner as a standard dreambox will fry a nds3 card in 10-15 seconds, hope this helps..
                            • .: JaCkPoT :.
                              • Aug 2008
                              • 5607
                              Showtime use irdeto 2 mate not nds3
                              ___________________
                              DM800s HD
                              Openbox S10
                              TM500
                              DM500s
                              Maxx 110cm Dish
