crack dreambox
  • lobo do lis
    • Jun 2012
    • 5
    crack dreambox
    I have a dreambox DM500S.
    Is blocked with username and password do not know.
    I need to know the name of the file to decrypt the entry into my dreambox.
    Just for my own use and for educational purposes.
    thanks for hosting this forum
    best regards
    did you try the default password for them thats what it usually is
    • piopat
      • 708
      the default username is ROOT
      the default password is dreambox
      usually only the password is changed so id say your username is still root .
      do you have tuxbox or tuxcom installed ? if you have you can delete the current password ,or if you havent got tuxbox installed see if you can install it from the addons menu . if you have it or iinstall it follow these instructions
      You can reset your dreambox password using dreambox remote:
      1.install tuxbox commander using addons button
      2. Start tuxboxcomander
      3.go to in /var/etc/ and open the file passwd
      4.press 4 on remote to go into edit mode.
      The first line is root:*****:0:0:root:/home/root:/bin/sh
      where the ****** delete it (by using remote arrows to move cursor right and then pressing volume minus)
      delete *** until upto :0:0:root
      and press ok and exit -> save
      the first line should look like this after the edit
      root::0:0:root:/home/root:/bin/sh
      then login with user root and password leave empty
      if you dont have tuxbox installed and cant install it you will have to flash the box ,flashing means putting new tv software into the box .
