How can I load EPG data from local folder,not from satellite?
  • newlux
    • Mar 2009
    How can I load EPG data from DM500's local floder,not from satellite?
    If I can produce EPG data named 'epg.dat' by myself and the format just like we get from the satellite
    Then put it into dreambox /var/epg (epg folder creat by myself)
    Is there anyone can help me?
    or tell me how the EPG works?(Gemini 4.6)
  • dingbat
    • 6
    I've looked into this before and I have not found a way of doing what you are talking about. There are plugins that will provide EPG, but none that will integrate that EPG data into enigma.
    Nabilosat are the only people I know who have done this. They have done it for Sky IT+ Sky UK is on the way. But this is only for E2 images.
    Some EPG plugins I've used are,
    MV + XMLTV,
    WeekEPG,
    EPG-Evolution
    EPG-Evolution is probably the best of the bunch because it does everything automatically for the packages it supports. The box just needs to be connected to the net.
    D
    • alunfennell
      • Oct 2008
      • 1525
      I would use Evolution software all you have to do is load extepg.cfg & extepg.so into /var/tuxbox/plugins and remote.xml into var/ect/ press the yellow buton select Evolution to load it then press Red and select external EPG, it works realy well and gives you a 7 day tv guide.
      **The Worlds Best Interactive F1 Strategy Game**
      • rruunneerr
        • 62
        Can this be used on DM800 E2?
        • alunfennell
          • Oct 2008
          • 1525
          You need the Enigma 2 download of Evolution you can get it from here http://epg.evolution.project-x.us/files.php
          Regards:
          Alun
          • father ted
            • Feb 2008
            • 1389
            Regards:
            Alun
            alun! is this the same for a 600 pvr?or is the first one for it?pli image on
            • alunfennell
              • Oct 2008
              • 1525
              Hi Fater Ted !
              You will have to use the Enigma 1 version for your DB600 pvr, It works on most images, Ill try and get new skins and updates over the next few days
              I found it realy good especially with the record function days in advance.
              Regards:
              Alun
              • berley
                • 567
                this worked great on the dm600 with pli jade but it was a chew finding out where the plugins were
                for anyone looking they are located here :-
                usr/lib/tuxbox/plugins
                thanks again allun much appreciated
                • piptaps
                  • 399
                  on my dm500 its only giving me 1 day EPG. What do i do to get 7 days?
