Dreambox 500s disconnections
  • kawwa3
    • Mar 2009
    Heyy all,
    I'm rather new here, but im keeping up with everything. Lately i have been forced to flash, then JTAG, and reflash a couple of more times in order to get my dreambox working. However, im having some kinda problem with my cardsharing. Im subscribed to a local server, and two local external servers which i have integrated into my CCcam.cfg .. i also have these servers on my satellite tuner card on my pc, and using dvb dream along with winCSC which works just fine.
    On my dreambox, it keeps disconnecting from my local server and switching to my external servers which seem to fail due to bad connection. im using a gemini 4.6 image .. since im in love with how the percentage shows up in the channel list. now im not sure if its the server, my image, my CCcam version or else causing this problem.
    On my pc, occasionally or rarely, an error shows up as BAD_REPLY_FOR_MSG_CARD_DATA .. or something like that .. anyway .. this seldom happens, but key errors are quite frequent but it seems to skip over them .. does the dreambox not skip that kinda error ???
    If you belive its the image, can you please reccomend any other one that wont disconnect my servers. and does anyone know any other image with the percentage thing on the channel list???
    If you believe its CCcam 2.0.11 then please tell me what to do ...
    If you belive its something in the settings that i can fix, please tell me how ...
    thanks all...
    EDIT: oh and btw .. additional question .. can this be in any way due to not setting up any port forwarding in my router? do i need to?
  • kawwa3
    • Mar 2009
    please help !!!
    any suggestions?
    • alunfennell
      • Oct 2008
      • 1525
      There is no discussion regarding cardsharing permitted on D.K, I personally use the Nabilosat Image Darkstar 2 running CCcam 2.0.11 with very little issues.
      Regards:
      Alun
      **The Worlds Best Interactive F1 Strategy Game**
      • opsmonkey
        • 5379
        Cardsharing discussion is not allowed mate as said by big Alun but to use the dreambox for anything you really need to port forward your router.. The default is 12000 so try port forwarding that..
        check out this:
        PortForward.com - Free Help Setting up Your Router or Firewall
        to find out some info on how to..
        I use Gemini 4.2 and Cccam 2.0.9 with no probs
