Looking for an image to put on a DM528......anyone ever used one for Sly Satellite 28.2E
Not much info readily available so any input appreciated
Freck
Freck
same as a dm500s m8.. the 518/528 are just the 500s with internal psu,s card reader removed and upgraded boards ect,regards mdt
Commando works perfect on the 528,so does Pli Jade.
Dreamup recognises the box as a DM500 and flashes as normal.
Also flashed it via ftp to tmp and that went off nicely too.
Only downside is the lack of a scart connection altho it has component out......
Theres was some slight differences in the Pli menus i thought but everything is ok.
So basically its a DM500 with internal psu and minus a scart and card reader.
Job done!!!
Thanks for the help.
Freck
