Dm500
  • konatist
    • 392
    Dm500
    My mates just got a DM500 its got gemini on it but when he goes to enter set up menu with the remote control to get the IP adrress off it it asks for a password he has tried the normal 0000 but cant get in it
  • alunfennell
    • Oct 2008
    • 1525
    HOW TO Change the forget pass on DM ! -
    Change the password on DM
    If you have forget the pass of your's DM , just make the next steps.
    1) Install and run TuxBox Commander plugin
    2) Change directory to edit /var/etc/passwd
    3) Remove the encrypted password.
    --> ATTENTION !!!! THE passdw file only !!! NOT the passdw-
    3.1) In the file /etc/passwd is the line:
    root:b:0:0:root:/root:/bin/sh or something as !!!
    root:dkjhfhlksfdiueyr736592cigsdjgfj:0:0:root:/roo t:/bin/sh
    3.2) the password field is the b or the encripted string dkjhfhlksfdiueyr736592cigsdjgfj
    3.3) Delete the b or the string .
    The line now is:
    root::0:0:root:/root:/bin/sh
    (for the DM500, if you are using an other DM keep the
    root as it is, you must delete ONLY the string)
    4) Save the file and exit
    5) Telnet to your DB with root user without password
    6) Create a new root password with the command : " passwd "
    If you want put the original file with user:root and pas.:dreambox in one directory in your's DM and if you forget again the pas. then just copy the file passw in the original location
    I have make it and it works
    Sorry for my English
    Bye from Transylvania
    (31-March-2008 21:41)
    The line now is:
    Or You can try this using Tux Commander:
    Once you have located the file passwd (not the one with passwd-)Somewhere into(/var/etc/passwd) with tuxcom, press 4 on remote to go into edit mode.
    The first line is root:*****:0:0:root:/home/root:/bin/sh
    where the ****** delete it (by using remote arrows to move cursor right and then pressing volume minus)
    delete *** until upto :0:0:root
    and press ok and exit -> save
    the first line should look like this after the edit
    root::0:0:root:/home/root:/bin/sh
    then login with user root and password leave empty
    you could telnet and change the empty password with your own so known can easily hack into your dm box or you can just reflash the receiver and set it up again.
    Tux zip
    ftp to /var/tuxbox/plugins
    Regards:
    Alun
    **The Worlds Best Interactive F1 Strategy Game**
    • shahbana
      does this tux.zip can be use on dm500s
      • EAMO 2
        • 1201
        Yes but you might find it easier to use null-modem & flash new
        image to box, then you won't need password to enter menu.
