Remote Control Shortcut to Record on DM500S?
  • vinnys
    • 10
    Hi, I read a Dummies guide on the 500s and it pictured a recording shortcut for the DM500s, the shortcut was something like OK and GREEN or something like that. I can't find the document anymore, I have already set up and mounted some NFS shares and would like a quick way to record a programme.
    Vinnies
  • mikeyb
    • 161
    Have you got Ngrab set up?
    • alunfennell
      • Oct 2008
      • 1525
      Add a record button to a DM500s remote
      There is no "record" button on a DB500s remote control so you can only record using the timer function. But a record button can be "added" by modifying the rcdmxxx5.xml file (and as I recently flashed my DB I lost the record button and had to remember how to do it... hence this post).
      Anyway, copy the rcdmxxx5.xml file from /share/tuxbox/enigma/resources/rcdm5xxx.xml and save it to your PC.
      Make a backup of it.
      Use the "edit > find" facility to search for RECORD and make the following change:
      change:
      <action name="record" key="record" flags="m" />
      to:
      <action name="record" key="mute" flags="m" />
      After editing it save it to /var/tuxbox/config/enigma/resources/ as the original file is read-only () and can't be chmod'd with an FTP program.
      You can now use the mute button when in DVR mode (the yellow button) to as a record button on a DM500s remote.
      Regards:
      Alun
      **The Worlds Best Interactive F1 Strategy Game**
