i have a dm 500 s and it has crashed. i was running a gemini image on it on cc cam 2.0.3, it is now saying fta instead of net, do i need to run c lines again ? help plz
dreambox dm 500-s help
try a re-flash after you have backed up your c**am config file. there is a G.P. 4.2 img that i posted in the downloads section with c**am 2.2.1 built in and c**am info and ecm info plug-ins also. re-flash your box ftp your configs in, stick a channel list in and you will be back up and running in 1 hour max. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
If you can log into dreambox then it looks like its alive. Use dreambox control centre to connect to the box. download this image here in 1st post http://www.digital-kaos.co.uk/forums...elease-277813/
Now you have dreambox control centre connected to box, click on the ftp tab in bottom right hand corner.Browse for image file you downloaded and transfer it into the tmp folder.Now click on telnet tab in bottom right hand corner and enter cd /tmp && eraseall /dev/mtd/3 && cp Commando_14-6_dm500_Release.img /dev/mtd/3 && reboot then press enter on keyboard After about 3 mins your image should be flashedComment
, ive got firezilla and logged into dreambox, how do i download a new image ? thanks
