DM500 jtag successful, but cannot connect using any method.
  • Philthy
    • Apr 2009
    • 19
    Hi all.
    After a lot of reading, head scratching and swearing, I got my DM500 jtagged successfully. It recognised the corrupted bootloader, and flashed itself without problem.
    My problem is, I cannot, and never have been able to connect via the rs232/null modem cable, and therefore, cannot flash an image into the box. When I got the box, it would not connect.
    I have tried:
    Four different versions of dreamup, including the patched one.
    Three computers 2 pc's 1 laptop with usb/serial adaptor.
    Every com port available to me on any of those machines.
    Two different null modem cables, both brand new.
    I have also tried FTP'ing into the box, but as yet, it does not connect via IP. Ditto any other means of connecting via IP, telnet/http.
    Where am I going wrong, is there any other way of connecting?
    Is it possible to flash an image using jtag, or any other flashing tool, or shall I go and buy another null modem cable, and try all the various com ports/computers/cables/adaptors again?
    Has anybody else ever had a DM500 that wouldn't connect via rs232? I have had the box apart, and checked the null modem cables from pc to the PCB in the DM500 using a meter. All are ok. The rs232 socket is fine, the plug is in the board properly etc.
    Thanks in advance
  • dexyweescot
    • 44
    you seem clued up so i take it you have checked and rechecked the ip settings?
    • Philthy
      • Apr 2009
      • 19
      Yup, one of the first things to check.
      This gets even more curious if you have a few minutes to watch this:
      [ame=http://www.youtube.com/watch?v=iZgTUqEWcoo]Dm500 won't connect - YouTube[/ame]
      Weird or what?
