very very odd...
  • buttso
    • 5
    very very odd...
    I have a dreambox 600s on mmd*S and my box was working away very happily.. I dont turn it off really.. just let it work away doing its thing..
    I shut it down , and was moving it to another room, but when I brought it to the other room it wouldnt pick up any channels, so I brought it back to the other room and it still wouldnt pick up any channels , plugged the chorus box back in and checked both cables with it... signal is fine.
    I am running Pli iolite 2008, so I reflashed the box and tried again.. then I noticed that when I tried to find the channels it would find the chorus mmds transponder no problem but wouldnt find any services.. ziltcho.. nada.. nothing...scan all the way to the end...
    tried a different Pli Jade image just to be sure.. double checked my terrestrial.xml as well
    rechecked the cables, recrimped two of them.. but nothing...
    anybody have any ideas?
  • despdan
    • 544
    First off have you a 600s or 600t?
    Where are you in Ireland?
    btw you posted in the satellite section you would be better off posting in the cable section.
    • buttso
      • 5
      odd
      I am in cork, I have a Dm600s
      ok I will drop a thread over there so...
      • firestorm
        • 1550
        has moving your box disturbed the internal tunner in the box as i think they are plug in types on the 600
        • buttso
          • 5
          AAAA HHHHHAAAA
          hello
          thanks for your suggestions much appreciated
          after farting around with the device for hours I will never get back... I found the problem
          I moved the dreambox from one room to another, and the power from the antenna must have blown the tuner in the device....
          what I was missing was the "AGC" was reading as zero.. I couldnt remember if this was meant to have anytype of reading.. but I bit of a look around told me this should have some sort of reading...
          replaced the tuner and off she went..
          • opsmonkey
            • 5379
            Glad you got it sorted.. thanks for the reply, knowing how you fixed it will help others in turn
