The technomate is completely different to the dreambox so these will not work with your box. For the technomate I think you need something called Clarke coonect.
Yes it will work fine on all enigma 1 boxes.
As long as they are saved as type 2 in Dreamboxedit settings for enigma one. I sent my m8s settings and they work fine on Dreambox 500/600/ Relooks/Ipboxs/Eagles and Tm 9100/9100s
Clark Connect is a a vm for running a linux server on a windows PC
I have tried uploading your bouquet shirehorse but found I had to trim it down by removing all the bak files before it would fit. I'm using the nabilo darkstar 2 image if that makes a difference.
After adding the files any channels I went to said no service (even bbc1) and all were saying Nagra as the encryption used. I rebooted and then it just stayed on the darkstar 2 logo for about 10 mins. Luckily I could still ftp to the box and just loaded my old config back on.
Not sure if it was something I did wrong or if the box just got itself in a twist.
I assume I was safe in thinking I could delete the bak files before uploading your bouquet?
On nabilo I think S*y is set to 28.4E rather than 28.2E. you could try editing the transponder and change it from 282 to 284 to see if that helps.
Please do not make a post simply to say "thanks" folks, please use the " thanks" button at the bottom right hand of the post you want to say "thanks" for.
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
