easiest way to flash a dm500s?
  • cboyer
    • Feb 2012
    • 271
    hi just qwondering if there is an easier way to flash a 500s than using dreamup? i did my dm800hd using web browser
    thanks in advance
    "I've got it made. I've got a wife and a TV set -- and they're both working."
  • **OVERRIDE**
    • 199
    Use flash wizard pro,runs through your ethernet cable
    • plasterer
      • 1631
      Telnet is as easy as it comes mate follow the guides on here.......Paul
      If your Happy with the Help push the Thanx button
      PAUL
      • Elric
        V.I.P. soft lad
        • 853
        ftp the image file into the temp folder of box and install the image via
        the s/ware update menu on the box
        • cboyer
          • Feb 2012
          • 271
          alright people i tried doing it via telnet on dcc and ****ed it , it said that it flashed the image succsefully but when i rebooted the box nothing happens at all and when i try to flash a new image via dreamup i am using usb to null as my lappy doesnt have a com port this should work as i have fixed my dm 800 this way and dreamup does read it but when it says connection prepared now switch on the dreambox after i switch on the dreambox nothing happens?
          thanks for your help peeps
          • Elric
            V.I.P. soft lad
            • 853
            use an older version of dreamup
            • cboyer
              • Feb 2012
              • 271
              which 1 you recommend mate? and do you have a link for it? cheers bud
              • Elric
                V.I.P. soft lad
                • 853
                ive always used 1.3.3.4 you can find it here Dreamup 1.3.3.4 - Downloads - Digital Kaos
                • PaphosAL
                  Old Git
                  • 1064
                  And make sure you have the correct COM port selected, as found in Device Manager. It's a common mistake to think that because no 9 pin serial port exists on modern lappies, then a USB - RS232 adaptor would be COM1 when plugged in. Wrong...
                  COM1 is usually already hard-wired internally to the docking port socket, so even if a docking station is not in use, COM1 is still reserved for it, including an IRQ.
                  Why not consider a proper PCMCIA-232 9 pin Serial port? ?7 on fleabay, inc free P&P.
                  Cheers- AL
                  • cboyer
                    • Feb 2012
                    • 271
                    my laptop aint got a serial port mate? i thought usb to null was the only way possible if you have a lappy?
                    • cboyer
                      • Feb 2012
                      • 271
                      thanks peeps il let you know how i get on as i cant do it yet as we are moving house and the misses has packed it and sent to new house :S
                      • PaphosAL
                        Old Git
                        • 1064
                        But your lappie surely has a PCMCIA card slot, no? So I'm talking about you treating it to a genuine RS232 Serial Port with a 9 pin male socket to connect your null-modem cable into, with it's own hardware IRQ and a likely serial port allocation of COM2 for DreamUp, PuTTY and so on.
                        It's a no-brainer, trust me on this...
                        Cheers- AL
                        • nush
                          • Oct 2008
                          • 178
                          use the root.cramfs method, its easiest method for dreambox500s
                          • cboyer
                            • Feb 2012
                            • 271
                            Cheers- AL
                            oh i trust you bud its just that i have never added anything like that to lappy before is it easy?
                            • cboyer
                              • Feb 2012
                              • 271
                              what is tbhat method mate? is there a tutorial anywhere? cheers
                              edit:: found a tutorial pal but i cant use this method now i have knackered my box
