Connecting a dreambox to existing motorised dish
  • modey
    • 60
    I've just got a dreambox to replace my technmate 5400ci, but haven't yet got a null cable to flash the box.
    quick question, as my dish is already aligned to the various satellites ow hdo i tune the dreambox in to these, is there a set procedure? i used disq 1.2 to sort the technomate out as i couldn't get uslas to work.
  • Curious123
    • 2591
    Read this post?
    • modey
      • 60
      I had a quick loot at that and it only says about setting up a sat with a fixed dish?
      • opsmonkey
        • 5379
        What Dreambox do you have..???
        This is for a 800
        1 Go into Setup and Select Start Wizard
        2 Use Wizard to set up Basic Features/ hit OK
        3 Configuration Mode/ toggle the left and right buttons until Simple appears
        4 Mode/ toggle this until is shows Positioner
        5 Put in you Longitude
        6 Put in you Latitude and then exit the Wizard
        7 Watch Multi Sat TV
        • modey
          • 60
          This is for a 800
          I've got a dreambox500s, i've just put the gemimi 4.20 image but can't find any satellites, is doing the procedure above using usals as i couldn't get this to work on my technomate so i manually put in each sat.
          can i do this with the dreambox, do i have to import satellite and channels lists first?
          sorry about all the questions but after putting the image on and setting up the communication i'm a bit lost
          my dish is currently pointing at thor 1w
          • intrancer
            do manual search you .. select1w sat on in the menus and search i do this on the dm800. i had problems initally i used my technomate to point to point to 28.5e then connected my dm800 went into tune setting inoputed mt longitude and latitude (use same settings as your technomate) select astra and scan (manual)
            • modey
              • 60
              thanks for that, i have manged to scan thor 1w now and have channels for that sat, next question is how do i now do this for each different satellite?
              On the technomate i could add a transponder for a certain sat, then manually move the dish with the remote until i had a good quality signal level.
              can the same be done on a dreambox?
              • opsmonkey
                • 5379
                just choose the next sat you want to scan
                edit your satellite.xml file to fit the sats in range..
                check here..
                to make one
                EDIT.. try this from another user..
                Originally posted by Fano
                I had the same problem myself last week.
                Its Usals,it doesnt work properly on the 500s.
                I was confident my physical setup was correct.
                I deduced it must have been a software prob.
                I was using Usals setup and had entered my exact location correctly.
                Could only pick up 2 bloody satellites,5w and 8w.
                Decided I'd turn off usals and do it the manual way.
                Started at 8w,then moved east until I hit 5w.
                Then went to 13E and moved the dish slightly east in steps .
                Hit 13e,16e,19e and 28.2.
                I have about 20 sats tuned in now,all good signal.
                I spent ages trying to get Usals to work but it was useless.
                This is what I did to get it to work
                The DM500s doesn't support gotoXX. The long way is to use stored positions is described below.
                Please note that your zero satellite (1W in this example) will depend on where you are in the world.
                Go to Menu > service searching > motor setup
                Mode: drive to zero
                and press go
                Then change the mode to position and select 1W:
                Satellite: 1W
                Drive the motor to zero.
                Mode: Position
                Satellite: 1W
                then use the < > arrows to move the dish until you get a lock. STORE the position (I use the same number as the satellite).
                Then SEARCH.
                Repeat for 13E, 19E, 28E, storing the position for each.
                If you use gotoXX you shouldn't have to do it but I couldn't get it to work with my 7020 (and it doesn't work at all with a 500s).
                Your screens and options may vary slightly depending on the Dreambox model and image that you have.
                Extra info:
                Mode is position, drive to zero and a few options.
                SATELLITE has the list of satellites.
                In simple terms you drive the motor back to zero so you have a fixed position.
                Then you change the MODE back to position, select the satellite from the list next to SATELLITE.
                Then you move the motor (dish) using the < > arrows (these move the dish east and west).
                When you get a lock on the satellite you chose, you store it's position and then go to the next menu screen and scan it.
                • modey
                  • 60
                  none of that actually makes any sense for the image i'm using. I don't know how to manually move the motor with the remote and then store the satellites in that position
                  very frustrating, i get all the channels ok on 1w, even tried entering my longitude and latitude to see if i could ge goto x to work, and although it moves the motor, it doesn't move it to the correct postion for 1w so all the others are going to be wrong.
                  anyone help before i give up..please!!
                  • modey
                    • 60
                    sorted now, thanks for the help
                    • opsmonkey
                      • 5379
                      can you explain how you sorted it mate..?? just may help people in the future who find themselves in the same position
                      • battlestar42
                        • 18
                        just doing motor setup for sat trying to set up motor in house for 1w thor pluged motor into sat reciever my motor is technomate 2600 but getting no joy can any one tell me how i set it up i have dreambox 500s getting no light on motor wen i plug into reciever any help appreciated
                        • opsmonkey
                          • 5379
                          my light only comes on the motor when i try to move it..
                          have you set up your Lat / Long on the box and aligned the dish correctly to Thor
                          • battlestar42
                            • 18
                            motor
                            no i have not got the dish up yet as some one told me to plug into reciever and motor in the house and set up on reciever to 1 w thor and then put onto pole above gutter to the satelite i require but im new to this i have the dreambox 500s said you can move the motor next to reciever in the house thanks
                            • battlestar42
                              • 18
                              motor
                              need a tut on my reciever so i can put in my latitude and how to set up reciever
