Hi Guys,
I have held off posting for a week to attempt alloptions. Bought by dreambox on ebay it has pin code set and the root password is not the default Dreambox. The guy I bought it off doesnt seem to be able to help!.
I have purhcased two null model cables with USB adapters at the end. The box itself works fine I can pick up channels on it, but cant access the setup menu.
My example below is with ubuntu as that seemed to give me the best logging for the usb-serial driver
[ 33.880701] usb 2-1.2: new full-speed USB device number 3 using ehci_hcd
[ 34.035041] usbcore: registered new interface driver usbserial
[ 34.035050] USB Serial support registered for generic
[ 34.035075] usbcore: registered new interface driver usbserial_generic
[ 34.035077] usbserial: USB Serial Driver core
[ 34.036140] USB Serial support registered for pl2303
[ 34.036160] pl2303 2-1.2:1.0: pl2303 converter detected
[ 34.038372] usb 2-1.2: pl2303 converter now attached to ttyUSB0
[ 34.038386] usbcore: registered new interface driver pl2303
[ 34.038388] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 2446.889311] usb 2-1.2: USB disconnect, device number 3
[ 2446.889680] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[ 2446.889715] pl2303 2-1.2:1.0: device disconnected
[ 2458.082240] usb 2-1.2: new full-speed USB device number 4 using ehci_hcd
[ 2458.226226] USB Serial support registered for ch341-uart
[ 2458.226255] ch341 2-1.2:1.0: ch341-uart converter detected
[ 2458.228251] usb 2-1.2: ch341-uart converter now attached to ttyUSB0
[ 2458.228262] usbcore: registered new interface driver ch341
From the logs above you can see I have attemped with two different cables to test out 1: ch341 and 2: pl2303.
As you can imagine each time i lauche Dreamp up sudo ./Dreamup i get the usual connection prepared but nothing else
P.s. took one the cables to an old pc that had a serial port and dreamup still complained this was on windows xp.
From peoples experience, do you still think the problem is with the cable its self rather than the box and is there any other way for me to test these cables.
Cheers one and all.
ReddScreenshot from 2013-06-14 22:59:45.jpg
Cheers one and all.
