DM500s no network connection
  • geobart
    • Jun 2013
    • 4
    firstly sorry for my bad english, but i'm from France !!
    Since the begin of week I've lost my network connection wiIth no reason !!!
    My settings are :
    Routeur - Freebox
    DHCP enabled
    IP dreambox : 192.168.0.23 (with MAC adress)
    UDP and TCP 80 port open
    Dreambox :
    Network enabled
    DHCP no
    IP : 192.168.0.23
    when I test (yellow button) the 2 first are red, no network !!
    DNS are green OK !!
    Tested with DHCP enabled, same issue
    And what i don't understand is that DCC is working !!! sothis is not anethernet, cable problem
    So if you have any idea !!! PLZ help me
  • cactikid
    • 12017
    did you try powering off box and modem and router for 30secs then on ,it might connect then,common bug to reset.
    • geobart
      • Jun 2013
      • 4
      i've tested to reset the router, but not the box ! I'll test
      edit : not working
      • cactikid
        • 12017
        i said power off as in unplug not reset as that does more problems.recheck your network again,what way have you got it connected to lan,faulty cable?
        • geobart
          • Jun 2013
          • 4
          power off was unplug on both demo and router
          I consider my cable is good because FTP is working with DCC and Filezilla !!
          Network checked a lot of time, with many configuration but no improvement !!
          • psats
            • 823
            some box,s have network problems depending on the software installed
            have you tried rebooting via remote i have a spare box like that.
            • geobart
              • Jun 2013
              • 4
              what do you mean with "rebooting via remote" ?
              • psats
                • 823
                useing the remote control and chooseing reboot
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  i have had these issues before reflash box the check again make sure you have dchp enabled then reboot
