Network Issues with dm500 - s
  • lantip
    • Oct 2013
    Hello folks,
    I am facing some network issues with my db.
    I have red the topic http://www.digital-kaos.co.uk/forums...-issue-202122/
    I'm connecting the box through a switch
    But my current configuration under "Communication Setup" are: (Network & DHCP are both ticked)
    IP : 10.0.0.97
    Netmask : 255.0.0.0
    Type : LAN
    Nameserver: 192.168.1.1
    Gateway 127.0.0.1
    I tried un-checking the DHCP box, and I entered
    IP : 192.168.1.100
    Netmask : 255.255.255.0
    Type : LAN
    Gateway 192.168.1.1
    No results ...
    Any clue?
    Thnx & rgds,
    lantip
  • cunny
    • 4915
    Ok, not to sound funny here, keep it to 1 thread.
    Can you post router ip
    Sent from my GT-P5110 using Tapatalk HD
    • jay5880
      • Aug 2011
      • 17
      dm500s enigma 1 if you don't know what your doing get someone with brains or someone who can read this is enigma 2 dm800 ect
        Your reply to the OP is not very helpful, We are a community and as such should be helping each other no matter how trivial the question or even posted in the wrong section.
        Moved to the correct section
        Thank you
        • Kyle925
          • Aug 2013
          • 49
          I had a similar issue where it would be connected fine but when the ethernet was removed and reinstered it wouldnt connect in the end rebooted the router and box and it was ok, when the DM 500 defaults to the IP: 10.0.0.97, it generally means there is an error somewhere in the connection, I had a box and a reflash sorted it but it could be a number of reasons. Try a direct connection to the router/modem via ethernet and see if that works which if it does then it could be the switch or the config if not then it could be something to do with the hardware within the box (IE. dodgy ethenet module). As mentioned this can be a pain in diagnosing this typoe of fault as their is so many variables to go wrong.
