Is there any way to flash firmware a DM 500 without a null modem cable?
well you should be able to thru your network internet. using your ethernet.
check this video out
what image are you trying to install.
Telnet Commands
To flash an image using Telnet
This method will only work with a .img image file.- Rename the image file to backup.img
- FTP the image file to the /tmp folder on the dreambox
- Telnet to your box and paste the following command:
cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
To telnet, click START > RUN and type Telnet ip.address.of.dreambox
A command window will appear, enter username root and password dreambox.
To backup an image using Telnet
- Telnet to the box and paste the following command:
cat /dev/mtd/3 > /tmp/backup.img
- FTP to the box and navigate to the /tmp
- Here you will find the backup.img file.
